Thanks for the test Barry. I sold my DVX so it is no longer here to compare with. However I think you test confirmed my claim that I have NEVER experienced issues with using the DVX in the cold. I actually did a search on this forum and there were ZERO posts about the DVX's focus ring sticking in the cold. I just assumed lubrication is no longer considered a nose bleed technology and the lube used in these cameras nowadays are more than sufficient for shooting in anything other than extreme arctic conditions. A downgrade in lubrication performance would be the last thing on anyone's mind. Maybe Panasonic thought too lightly of lubrication and simply over looked it in design? It would be pretty difficult to believe that the product managers desired for these new models to have degraded focus ring performance.
What really bugs me about the HMC is that on my unit (and many others' here) the large amount of force it takes to get the ring going is disaproportional to the force it takes to spin the ring after it has engaged. If the ring was stiff consistently, I can work with that and just apply consistently higher pressure when the lube thickens up. However, it is VERY difficult to be focusing when the focus "jumps" due to higher amount of force it takes to get it going.
You mentioned that once the ring started going, the focus was relatively smooth. However, once you slow down to approach a focus point, the ring would come to an abrupt stop due to the thicker lube, instead of stopping gracefully and smoothly. And once you stop, you have to deal with the sticky stand-still ring issue again..
