JPNola
I am rapidly reaching the conclusion that stepless iris is not possible with electronic iris. The fact that the Sony Fs7's control wheel on the grip is clicked means that it will never be capable of stepless, infinitely variable control of iris. Maybe such is possible with the user wheel on the side of the camera since that wheel is not clicked.
Is there any iris control outside of manual control such as the Nikon adapters that will yield truly step less iris changes? As far as I know, even the RED camera has stepped iris when using lenses with no iris ring.
Not sure if you have seen this but the Arri prototype top handle is designed to eliminate VF "flop" on the Fs7. With the original Sony design the VF lock controls both fore / aft and left / right movement. The problem with that is when you loosen the lock to adjust fore / aft positioning of the VF the VF can slip on it's horizontal plane. The Arri prototype design prevents the VF from being able to skew horizontally-
http://cinescopophilia.com/wp-content/uploads/2014/11/ARRI-PCA-accessories-for-sonyfs7-3.png
Note how the LCD / VF is on a fixed L-rod that does not allow the VF to move horizontally.
Impressive that Arri has already recognized this design dilemma and addressed it. The Arri design does limit the range of positioning of the VF / LCD but the positions it negates are not positions I was likely to use anyway. For example, the VF / LCD centered over the top handle.
Since it's ARRI the price of both their top handle and shoulder plate is likely to be steep.
Now, if only someone would design a way for the loupe to be flipped up without it detaching from the LCD, like the system on the EX3's loupe. When shooting Run & Gun I am having to wear a lens pouch for storing the loupe when I want to operate strictly from the LCD, sans loupe. Another Fs7 niggle of mine is that the bottom of the control grip is not rubberized. It often ends up being placed against the ground or table surface when setting the camera down. The design team HAD to know that the bottom of the grip was going to see a lot of wear and tear.
I know, I know....never purchase the first model of anything. And there is no "perfect" camera. Although the HDX 900 and the Sony 600 Betacam came damn close to being perfect.
( my apologies o F3 / F5 / F55 users for another Fs7 post. If there is a Fs7 forum please direct me to it. This post pertains to all cameras in general so show me some forgiveness if you would! )
