This Pilot is in good condition and hasn't been used very much compared to most second-hand units.
The following items are included:
*This Steadicam has custom springs that give the Pilot 20% more weight capacity. In our tests, the rig can handle 12 lbs vs 10 lbs for the standard springs (this is not exact).
Note: The standard springs are still included but should only be installed by Tiffen or a mechanical expert. Never attempt to remove or change the springs unless you're absolutely certain you know how to do it safely. The springs are under extreme tension and could cause serious injury if handled improperly.
$3500 - Available in the U.S. or Canada - No Taxes / Import Duties either way
See Also: http://www.steadicamforum.com/index.php?showtopic=15406
- Pilot Sled
- Iso-Elastic Arm
- Low Profile Vest
- Upgraded 6" Monitor*
- Upgraded Springs*
- 2 IDX batteries
- IDX battery rapid charger
- Steadicam backpack/case
- Several balancing weights
