standby and time code breaks...
schteevie
if I have the camera set to standby for tape saver, it sometimes will go from the grey standby status to the green pause, and I can hear it repositioning the tape, and then it will go back to standby... it sometimes does this several times in a few minutes.... other times it will stay on standby for over an hour with no issues...??
I can almost always expect to later find a timecode break and some blue, or it will recue back a second or two into the previous shot if it does the thing where it goes from standby to pause on it's own...... any idea why it does this...?
Re: standby and time code breaks...
If you black (or stripe) your tape, you won't have any problems. You could also use the Rec. Search feature.
does anyone bother blacking tapes anymore?  I hought that was old school...  I can't get into the time and effort to do that - not to mention the added head time on the camera.
anyway - the time code breaks I can live with - but the unexplained "pause/standby/pause/standby" thing the camera intermettently does, is anoying - what is that about...?
like I said - it doesn't do it all the time... anyone else notice this happening on thier camera?
You can change your camera to go to standby instead of powering down. Go through your menus and change the setting.
Powerdown/standby is used to save batteries and heads.
Just use Rec Check button on top of camera after standy or powerdown to re-sync the timecode and you shouldn't have timecode breaks.
No need to blank an entire tape and add wear and tear to camera heads.
I have it set to go to standby and not power down...
I guess I am the only one noticing that it cycles through standby and pause sometimes on it's own...
is no one else noticing this?
