I've got a shoot Wednesday and it's going to be standard def. I planned on using DVCPro50. It's going to stream to Final Cut on the set and I have been testing that.
I did not have a DVX before the HVX so I am not sure if this is a problem across the product line.
There is alot of aliasing issues around any straight lines lets say 30º from flat level, alot more than I ever expected. The camera is set for 480i/60i Video mode. All other settings were default. Scene file is set to 1.
The picture dances with jaggies when tilting vertically across any horizontal edges, more than I have ever seen in a video camera before. I am used to seeing footage shot in BetaSP or Digibeta. I didn't expect the HVX to be as good as Digi but I was hoping close to SP. This level of aliasing will probably be unacceptable for the client. The picture is very sharp, but the dancing is not gonna work. I tried turning the detail down. First tried -7 to see what that looked like, too soft. Then I set it at -3 and that helped some but not enough.
I then tried 480i/30p mode. Perhaps a subtle difference. However, the clip came into Final Cut, streamed over firewire, as 29.97 interlaced not 30p.
I saw another thread mentioning about using Cinema Tools to conform footage to new rates and tried to conform 29.97 to 30 but I am not sure how to operate Cinema Tools and all it did was break the link from the clip in FCP to the original media. I can relink but it doesn't help with a solution.
Does anyone here have any suggestion that might lead me to a solution?
Thanks for any info..
