Standard def via SDI?
wuntrikpony
Anyone have any insight into why a standard definition feed cannot be output via the SDI connector on the FS700? I am feeding a Marshall vLCD70xp via the video input and I cannot get a signal. I've tried every combination of video out settings at this point with no luck. I am shooting 1080p24 in FX quality. I have a smallHD evf connected via HDMI with no problem.
Not too familiar with the FS700 myself, but SDI signal is very different from composite and component signal.
Looking at the specs the FS700 has a video out via RCA which should be sending out the composite signal that you need. You will need to go from the RCA out on the FS700 to the BNC video in on the Marshall.
Component out will work as well but looks like you need their mini-D ternimal cable for it.
