rbirnbaum
So I got hold of 3 units and they all come with all the boards. I have 2 F35 and that way I will keep another one for parts.
First impression is that this is an amazingly built unit. Just sits right into the F35. Whole thing feels like a ‘real’ camera. Great not to have bunch of sdi wires flying around. And yes, the record light is on and I get tally in my evf... on the shoulder it’s rock solid. You really feel one with the camera. Even holding it in cradle ‘like a baby’ it’s really stable. I like the fact that I can get 444 10 bit out of it.
Problems are, that docked at the back, where I prefer it, the camera has to be powered from the top. Since I don’t need an if box in this config, I’ll convert one, remove it and use the mount so that it’s dockable at the top. I would prefer it if it was elsewhere. Definetely a battery belt is the way to go in this config.
Something else that is weird is that the mic inputs are on the bottom of the srw1 which makes it a bit weird if docked at the back. One great thing about the srw1 is that you can control audio levels... it has a lot of options, so you can get great audio if you are going solo, or with lavs if you are super low budget.
Will post more findings as I play more... my initial plan was to rip the internals and fit the necessaries for trigger record from any recorder/monitor in an if box. Basically making the camera think there is an srw1 attached but I may reconsider and use it just like that.
And yes, this tech is battery Hungryyyyy....
