Viddovation
So, I've been digging through the SRW-1 service manual, trying to figure out how the control signals work, and I came across the following:
Bottom line - it would appear that while the SRW-1 with HKSR-103 can record true RGB 444 50p, it will only play that same gootage back at 25PsF, dropping every other frame. If this is true, a tape based workflow for this framerate and color space would require a different deck for ingest.
Anyone know more about this?
Sony SRW-1 Service Manual said:HDCAM-SR decoding
The played back data is re-converted to parallel data on the DPR-232 board, and is then input into
PIERRE * (A) IC900 and PIERRE (B) IC1100 through the FPGA IC1400.
PIERRE is a data compression decoder of HDCAM-SR. Two ICs of PIERRE are used for the 4:4:4
signal, 4:2:2 50p/59.94p signal or the dual stream 4:2:2 signal, and one IC for the 4:2:2 signal as in the
case of MARIE. The PIERRE output data is converted to serial data by the FPGA, and is then sent to the
DIF-142 board.
When HKSR-103 is attached, the 4:4:4 50p/59.94p signal playback format is 4:4:4 25PsF/30PsF, which is
simple playback for thinning every other frame.
