Squeeze and Anamorphic
Hi,
I have a Question about squeeze mode and the anamorphic adapter lens.
Am I supposed to film in 4:3 or Squeeze-Mode when filming with an adapter-lens?
I want to buy one, but I'm not sure if my computerprogramme is capable of getting the image right.
So do I film in normal 4:3 and the lens does it's thing or do I have to a little bit more with the PC?
I also saw some footage filmed though a anamorphic projector lens. Am I supposed to zoom in till the vignetting is out of the frame or should I film everything and cut the convex lens frames out?
I'm asking bekauce of the solution might get a bit f## up because I'm zooming and also cutting parts of the frame. So do I have to shoot in squeeze mode though the anamorphic adapter to get the 16:9 to the next level or is it possible to shoot in 4:3 through that lens?
If you're using the anamorphic adapter, shoot 4:3. Then, in post, you have to change the pixel aspect ratio to "unsqueeze" the footage, because the NLE will read it as 4:3.
ok.thank you again.
