guerillaEMPIRE
it is really bugging me, and i was wondering if it was possible to safely clean it? its located inside the viewfinder itself. any help would be appreciated
Amen to that. I use this exact rule for my photo gear - I just keep the sensor and the lens elements clean and ignore the rest.Nick Walters said:If it isn't showing up in footage, then I wouldn't even think once about it..
You can actually use microfibre cloth, cleaning liquid etc if it is specifically marked for use with multicoated optical elements (like lenses, filters...) and if you know what you are doing.inside there is specially coated so DO NOT USE ANYTHING to touch it.
You can use the compressed air, but it must be the pure version and you must only use it briefly and from a distance. If you use it directly and for longer time, the sudden drop in temperature may damage the multicoating.the manual says to use a blower...NOT compressed air either.
