soundxplorer
I'm wondering if the DVX can do this. Basically the idea is, on other cameras I've used, you can "lock on" while using the auto-focus (usually center-weighted) and then move your camera around to frame your image.
For instance, if you want the object in the lower right corner of the frame (something closer to the camera) to be in focus while the background is softer, you could just point the camera at that object and let the auto-focus adjust, then "lock" in that setting and nudge the camera back over for proper framing.
It's quicker than manual focus of course. And sometimes I have trouble getting proper manual focus using the view finder, so I would use this method a lot with other cameras.
