FS7: Split remote for 2 inputs ?
bigmouthmedia
Is there a part that can be purchased to use in the remote port of the FS7II that allows two inputs ? So one could go to the handle, and another to a separate remote (ie like the Manfrotto 901 pander), and if you could plug in both at once, would it let you use either/or ? I know it has to be 2.5mm, but wondering if needs to have one or two rings on the tip.
Only reason I ask is that if I had that setup, it would be easier to go from tripod to shoulder with a simple removal of a plug instead of unplug one, plug in another when time is precious.
Note : I don't have an FS7ii (yet) but curious if anyone's done the above.
