TheRedMenace
Carbonite Member
I have all of the settings correct, latest firmware, using approved drives. The quality of the images it records (used ProRes HQ) were simply amazing...when it worked. First problem is with the 2.2 Firmware it won't playback on the device. Says there's a firmware error and you have to pull the battery and reboot. So now when I need to check takes, I have to pull the drive, go to the computer....huge time suck. THEN it started locking up. It was pretty much consistent in that it would do it either at the end of a perfect take or when you didn't have time to do it again. The worst was we were doing these long 2 minute dolly shots, every 3rd or 4th one: crash. The file is there but it's truncated and unsalvageable. Nothing worse than looking at a 3.36GB solid gold take that's there but gone. Upside; it did become rather exciting when you held your breath, pushed the stop button and were rewarded with success. It felt like winning the lottery. Downside was I felt compelled to keep checking the start and stop before each take to make sure it wasn't going to freeze (let it run for 15 seconds or so) and ended up a bunch of garbage clips to sort through at the end of the day. Not a big deal, just another time and resource waster. But the killing blow came when I went back to check shots after a series to find that several were missing. Just gone like a defector from communist China. I'm OCD, I check the REC almost as much as I watch frame and focus - I know for a fact it wasn't user error. So for the rest of the shoot I had to spend a maddening amount of time holding up production, checking and re-checking things at the computer before moving on to the next setup. If you enjoy being nervous, paranoid, obsessive compulsive and being asked constantly by the director; 'did we get it? Are you sure?' - it's a fantastic device.
Overall I wanted to love it but it was like swimming with Piranhas; thrilling but occasionally I would get bit and come up with something missing. I had a friend ask if I would recommend it. I would say this; not for a professional shoot. Ever. If you're just messing around and you can afford to suffer a disaster every other setup, go for it. Assuming all of the problems are addressed first, it could also use a belt clip, arm belt or a lanyard - there was just no ergonomic or pleasant way to mount the thing anywhere. It also needs to power on from either battery slot, not just #1.
All of the complaints I've read about image quality, interlacing, crushed blacks etc are user error. The quality of what actually makes it onto the drive is mind blowing. That said, I have a Ninja for sale and am currently shopping for a PIX 220 or similar for my next gig. The competition may cost more but it's far cheaper than scheduling a reshoot because you had a shot disappear into the mystic Ninja ether.
