GH5 Speedbooster with EOS IS lens + IBIS?
filmguy123
Anyone tried turning on IS on a lens (say for example the canon 17-55) while attached via a speedbooster to a GH5 body, and also turning on IBIS?
Does this work, or cause weird errors? Or not possible at all?
Dual IS is not a available with any Metabones, it’s either OIS, or IBIS, but never both.
If IBIS is enabled on the GH5, & OIS is enabled on the EF lens, the IBIS turns off. If you were then to turn OIS off on the lens the IBIS will automatically kick back in. When going on sticks, or similar, you’ll want to turn off both IBIS & OIS.
The combo of body and kens stabilization only works with a few Pannasonic Lenses, like the newer Pany Leica Primes and Zoom.
Cheers
Not surprised dual IS doesn't work with an electronic EF adapter since even my older 14-140 Panasonic lens doesn't work with it. So for me it is also OS only or IBIS only o the GH5. Probably part of the reason why I didn't care about dual IS as much.
