I've said before, size matters...
I don't see much point in getting E mt Rockinons. Maybe that's what you've realized. If you have an A7 it makes sense to get native lenses for the Auto features but you don't have those anyway on the Rockinons.
With EF you get speed booster and a standard metabones - 2 choices on the field of view, lower DOF and an extra stop of light - no brainer.
is there a reason you aren't just buying 1-2 wider e-mount prime vs. a whole new set?
What lenses do you currently have? What camera are you used to shooting with?
What would the cost be to do that as opposed to just buying an MK lens?
Thanks for the reply. I thought the optics in a speed booster would compensate for flange distance.
We have a set of Rokinons in E Mount that are great but massively cropped. I'm trying to find a way to enlarge the field of view without throwing these out and switching to EF mounts.
I think I get what you are onto- a "reverse speedbooster" of sorts. One that instead of narrowing the light path expands the light path. And in that makes APS-C lenses cover Full-frame, albeit with costs to image quality.
I'd like there to be a speedbooster in which it is possible to swing the lens of the speedbooster adapter out of the light path, similar to the "doubler" element on ENG zooms. That way you avoid having to swap from a speedboosted adapter to a standard adapter and any given zoom would have greater focal length range. A Canon 24-70mm would effectively become an 18-70mm. With speedbooster engaged it would be an 18-50, with speedbooster disengaged it would be a 24-70mm. And the beauty of such a thing would be that you'd only gain speed. At worse the lens would be its native speed. In the case of the Canon f/2.8 24-70mm it would either be an f/2.8 or an f/2.0. A f/2.8 24-70 becomes a f/2.0-2.8 18-70mm.
I've already named this the "Speedbooster Hot-Swap" so if you see Metabones come out with such a thing with that name, they've ripped me off. :cheesy:
