Specific Skin setting
Elmer_Lang
I'm filming someone I want to look their very best, are there any suggestions for customizing the HV20's picture. There is that one skin tone setting, but maybe one of you pro's has come up with a better look in teh custom settings.
Wanting to film in front of a bluescreen I've noticed that with the setting I have the contrast of skin with dark blue screen is causing problems, the skin looking a bit washed out.
best,
elmer
That's a tricky question. Settings on the camera might help but what about your lighting setup? In bluescreen lighting is the key.
You probably know this but a backlight on the subject will help create a warm mood making them look better. It will also help depth of field and make the image more three dimensional. Perhaps the subject looks flat. Is this what you mean by washed out? If the subject is washed out move the lights back. Control the aperture to help balance this as well. Also do you have enough fill light? Is your key light a fresnel? Focusable light? How close is the subject to the blue screen? I'm sure you are aware of HDV and keying issues because of color space. An intensity card could solve this. Also does the HV20 have a white balance? This may also help.
Regards,
-D
Thanks very much for that info, it will help going forward.
The subject is only a couple feet from the bluecsreen, I don't see how to get a back light in there, but I value your lighting tips!
I did get a pretty good picture by turning on the zebras and adjusting the aperture.
I also looked at Cine mode. It looked kinda flat. But maybe that can be adjusted in post to pop more.
best,
elmer
