TwinCitiesShooter
I've done the research, my brain is hurtin', and I'm on unfamiliar ground -- time to call on the experts (cue hero music). I need some active nearfield monitors and an audio interface for them. Here are the facts, and I'd love your advice.
1. I'll be using these to edit mainly corporate videos and low-budget local cable shows. 95% of my projects are just dialogue and royalty-free music. I almost never mix music or touch the EQ. If I do a project that has greater audio demands, I'll hire someone for the sound mix.
2. I'll spend what I need to spend, but for the rather simple projects I'm doing, and especially since I don't do EQ work, I'm not seeing the need for $500 speakers. However, I need an accurate, neutral sound.
3. I edit with Final Cut Studio on an Intel Macbook Pro. My current edit room is untreated, but my upcoming edit room will be treated.
4. I'll probably use the audio interface solely to connect the speakers.
I'm reading good things about the KRK RoKit 8 (also reading that the RoKit 5 is missing too much in the bass), but is it accurate/neutral? I was also looking at the Yorkville YSMP2, but the frequency response starts at 70Hz so it looks like I'd have to get a sub woofer.
For an audio interface, I was looking at the Edirol UA-25EX for $239. Then I saw that I could get an Mbox and Pro Tools for $400 at B&H. Pro Tools may be good to grow into in the future.
Does anyone have an opinion on the KRK RoKit 8 vs. the Yorkville YSMP2 for my use? Comparisons of them are usually geared towards music, not video. Are they adequate? Inadequate? Overkill? Do you advise something else?
Would both the Edirol UA-25EX and Mbox give a clean sound for hooking up speakers?
This cameraman and video editor thanks you much for any opinions.
