Spark scene file from 150 to 40
abeas
It seems all of the scene file settings are identical (in terms of the values) on the 150 and 40, except for the Master PED. I believe the Master PED on the 150 goes 0-100 while the 40 goes 0-15. So I have all of the settings the same for the spark scene file on the 40 (same from 150) except the Master PED. The Master PED on the 150 is -2. So my question is what should it be on the 40? I imagine there is a simple math formula to figure this out, but my math is terrible, unless it involves simple addition.
Simple math would be 6.67 HMC150 clicks per 1 click on the 40. Not sure if the cameras actually respond at that exact same ratio though....
and if its 0-100 on the HMC how are you and I using -2... so is it -50 to 50 ? I dont have my 150 near to check.
I've done some test shots, and to my eyes, I can't see much of a difference. I know Barry lists the HMC40 equivalents to his scene files in "The HMC Book" so that's why I figured there was an actual number to make it completely accurate.
