Sound recording in Native mode
dglasgal
Can anyone tell me their expierence in recording sound while shooting in native mode? If under or overcranking, then brining into FCP through frame converter, does the audio come in also?
thanks
Sound is only recorded at 30fps for 720/30PN for NTSC and 25fps for 720/25PN. All four tracks are silent for any under- or over- cranked speeds.
Alex
Right. If you're shooting native mode at overcrank/undercrank speeds, no sound is recorded on the card at all.
If you want sound and overcrank/undercrank, you must not use the native mode for those shots; use 720/24p mode and it'll record sound too.
Can I get good high speed/ slow motion effects with that mode?
Thanks!
Unless I'm mistaken (always a good disclaimer, eh?) you can record any frame rate in "over 60p", and extract the right frames in post (using, e.g., Panasonic's free FCP frame-rate converter plugin). So you can indeed record any over-or under-crank, with sound, in non-native mode without any downside except a) using the full 100Mbps bandwidth/storage and b) having to toss the extra frames later (which I think is pretty painless given you already have to convert from MXF; I think it's done at the same time).
