I am working on FCP v 6.2.
The issue I am having concerns the audio for the ceremony of a wedding. On tape, everything is perfectly normal. Only when I bring the audio into FCP does the issue occur.
When I play the file in the viewer, or place it on the timeline and watch it on the canvas, there are certain points where the audio skips. This skipping is similar to what happens sometimes when taking an mp3 straight into FCP.
I have tried a number of different things to get rid of this issue but nothing is working. It skips no matter what compressor I use. The footage is shot in 24p, but not 24pa, so I originally had it on a 30p timeline, as it should be. I tried it on a 24p timeline and same issue.
Strangely, the file itself has no issues when I open it in quicktime straight from my drive. I even went so far as to export the audio for the file from quicktime into an .aif and then link it with the video in FCP. Same issue.
The link below will take you to an audio sample of what I am dealing with. It is a little soft and you will have to bump your audio. It's right in the middle. You can hear the audio skip and stack up on itself.
http://web.me.com/hundsch/Site_2/Welcome.html
PLEASE HELP! Thanks.
