It's not the RAM that's causing it, that's for sure. What version do you have? (9.0a, b or c?) Be sure to have the latest update (9.0c) - depending on your hardware, some of it may be causing this crash for there were some known issues with some motherboard chips and what not. Updates with fixes for the latest versions (Pro 8 & 9) are available here:
http://www.sonycreativesoftware.com/download/updates
Get more Ram !!!!! + dont know your version, but I saw significant improvement when upgrading to 9 c from 9 b - I run 12 GB on i7 win 7 64 - I wouldnt go any lower than 6 GB Ram
Sweet Cheers. Well i have 4gb of ram thats plenty.
Perhaps not depending on what you're doing. If you said you had 12gb I'd say that's probably plenty, but I exceed 4gb of RAM on nearly every render I do of 1080p.
Also - check the video tag under Tools - preferences. There you can set the amount of ram for vegas to access. Mine was default 2 gig, even though I have 12. I bumped the number up to 8 which really helped. Also check that you get the right project settings (click on the "match media" if in doubt) + set the preview window to draft, auto.
You indicated that your computer is new. Check that you have the most current drivers for everything: graphics cards, etc.
Pete
How do I access the tools-preference video thing? Are you talking about in Vegas as I see nothing under tools which you mention?
:dankk2:
Edit-Ah found it, I think, is it the Dynamic Ram preview max (MB) or am I way off? Have upped it to 1 GB instead of 350mb and it still crashes.
Options - preference - video - sorry, my bad :embarasse
Try this, it fixed my crashing problem during rendering.
http://www.sonycreativesoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=650217
It’s not that difficult, just follow the instruction on the 3rd post. I was so desperate I was willing to try anything by the time I stumbled across this thread.Woah, this is too complex for me. What did that Blink guy do that fixed his problem? Will this help with mine?
