BasedMedia
Ive started this thread for anyone that uses sony vegas.
My project settings are the following:-
HD 1080-50i (1920x1080, 25.000 fps)
Feild order: None (progressive scan)
Frame rate: 25.00 (PAL)
Compositing Gamma: Linear
32 bit floating point
Gaussian blur
Blend fields.
Then, once you have setup your projext to the best quality for DV cameras save it as DVX Defualt.
Then go to rendering and choose WMV as we are going to be exporting it to that and my settings are the following:-
Video quality: Best
Audio: CBR (Audio isnt to much of a problem as it tends to sounds good when watched in 720p on youtube by defualt)
(THESE ARE IMPORTANT!, Go to the video tab, and choose)..
Mode: CBR (Two Pass)
Format: Windows Media Video 9
Image Size: 1280x720 (You can choose 1440x1080 if you want 1080p, your choice)
Pixel aspect ratio: 1.000 (Square)
Framerate: 25.000 (PAL)
Seconds per keyframe: 5
(HAVE OVERRIDE COMPRESSION BUFFER TICKED, AND CHANGE IT TO 8)
Lastly, video smoothness: 100.
Then move to the bitrate tab.
Have 'Internet/LAN' Ticked, nothing else, and have it at 6.67M
Then make sure you save it as you HQ default preset and wait for it to export. =)
Link your videos in a reply to this too see how it worked for you.
Gaussian blur
Blend fields.
Video quality: Best
