Since there is no subforum for the V1, I will ask here. The V1 has no built-in mic, instead it has two 3-pin XLR ports. If I understand correctly, 3-pin XLR means mono, at least if it is used for balanced audio. So, how do I get stereo sound? By using a stereo mic with two XLR connectors? So much for V1 compact body.
What do I do with my consumer-grade mics, in particular with the AudioTechnica 88 radio system? I found RODE VXLR converter, but according to reviews, it works with stereo plug only, converting stereo to mono. It does not work with mono 3.5mm plug (tip-sleeve). Should I just get a set of cables, not just an adapter?
I wish the V1 had built-in mic, even a crappy one. The FX7 has one, why not the V1?
