Sony Tape Stock
  • Start date Start date
G
Guest
Guest
Hello,
I have all Sony Cameras and Decks and I've used only Sony Tapes in all my equipment.
Can I use Sony tapes in my new AGDVX100A ???
Richard
Re: Sony Tape Stock
Jared, just to clarify...I also use the Sony tapes right now, but I am planning on switching to the MQ63s...this is ok to do as long as I clean my heads before the switcth, correct?
Re: Sony Tape Stock
well i dont know if you should.. if your entire chain is sony then stick with the sony tapes or your gonna hafta clean your decks everytime. Unless you are planning to switch EVERYTHING to the MQ's of course... but clean everything before you do the switch, and run a tape on each device for about 15 minutes because you may get a few dropouts right after the switch if you dont.
