cameramanben
Hi Sam,
middle gray, I'm afraid, isn't the middle of the recording (or at least very rarely is). To quote Wikipedia, 18% gray is :
but that is more about how it looks when captured or when displayed; it has no absolute relationship to the level of the recording. In a pure scene linear recording (with floating point values such as raw or ACES), 18% gray has a value of 0.18, where 90% white has a value of 0.9. With the two most common basic gammas applied, sRGB (for stills) and Rec709 (for video), the relationship places 18% gray around 48% and 43% IRE respectively, with 90% white card then coming out at 100% IRE in each. In reality, Rec709-based gammas frequently sit a percent or two lower, to help with the knee at the top end, but low forties is the most likely place to find 18% gray on a WYSIWYG video camera setup.
Most of the time going to 50% IRE on a Rec709-based look designed for 43% is only going to put you about 1/2 stop hot; with the knee at the top end and providing you haven't clipped it's not going to be the end of the world, but with lower-contrast looks - particularly those with even lower nominal 18% values - such as hypergammas or log, 50% could put you a stop or more hot. Mind you, with a log curve, you could claim that as rerating the camera.
Different transfer functions or gammas can specifiy nominal 18% where they like; eg Arri LogC - 38%, S-Log3 - 41%, C-Log - 33%.
Sony specifies 18% gray nominal values in the full names of their hypergammas, eg HG7 is actually HG8009G40 (800%, extended range and 18% at 40% IRE) and HG8 is HG8009G33 (800%, extended range and 18% at 33% IRE).
The 90% white level also changes with different curves, generally due to knees to compress wide dynamic range within the available integer range.
If you expose for the nominal 18% (or 90%) value under one 'gamma', you will still be correctly exposed when converting to any other,
Ben
This gray reflects exactly 1/5th the number of photons per square unit as compared to a reference white of 90% reflectance
Ben
