SOLD Sony PVM-740 OLED 7 Inch Monitor
Status
Not open for further replies.
Joshua Cadmium
Hello! I have a Sony PVM-740 OLED Monitor for sale. It comes with its AC adapter, plug for the AC adapter, stand, a Hoodman hood, a cheap case (definitely not a pelican, although the foam is similar) and a Anton Bauer QR-A200 Battery Plate (Adapts V-Mount to Anton Bauer Gold) so you can use V-Mount or Anton Bauer batteries with it. There is a fair amount of scratching and nicks on the protective cover, but the screen itself is perfect and you can get a replacement cover, although the scratching isn't as visible when the screen is on. There is also a fair amount of wear and tear cosmetically, but the unit itself works fantastically.
Since this monitor is part of Sony's PVM line and will accept a 10 bit signal, you could actually use it for color correction, as a supplement to a larger inaccurate monitor. (As well, Sony has solved the green bias that was originally an issue when the OLED PVM line first came out.)
I also found that if you were using this on a camera with a log mode, you could really amp the colors without affecting black and white values, giving the image more of a graded feel without using an added LUT.
I'm pricing it at $1150 OBO. PM me if you have any questions.
Thanks!
uc
uc
Status
