Duke M.
I'm selling my beloved and gently used EX1 camera. This was used to shoot a feature film and several shorts. Its in great shape and has only minor normal wear.
For $4,600 shipped in the Continental US. The camera will come with:
2 Sony BP-30 batteries
Sony charger
SxS 8 gig card
original booklet
USB cable
component cable
composite cable
I believe there is a CD but I need to look for it.
For an additional $50 I'll include an SWIT S-8U62 brick battery. Very nice and it holds a long charge. Much better than the Sony batteries plus it has a D-tap.
In addition to the camera for $75 there is also a Juice Design base plate with wing. Added to the wing is an arm and cold shoe. This is perfect for mounting a Nanoflash or wireless mic. The positioning helps counter balance the camera and does not interfere with cables or even big brick batteries.
The pictures are the actual items, but the NANOFLASH, MATTEBOX, LETUS EXTREME, MIC, FOLLOW FOCUS, TRIPOD, RAILS, ETC. ARE NOT INCLUDED. ONLY WHAT'S MENTIONED HERE.
The Letus Extreme with EX1 achromat is in another ad. The Nano is sold.
PM me if interested. I will mark this as sold when it is no longer available so you don't have to ask.
I would consider selling a Kata bag.
Also, a 8.9" ManhattenLCD HD 1280x800 monitor from a kit in a metal case. The monitor uses higher than 720p. It sizes for the 800 height and makes the width something like 1380 and over-scans the sides. That lets it pull focus even better than a 720p monitor. The monitor has an aluminum body, three 1/4" mounting points and is about 11" wide exterior. It has HDMI, component and composite in as well as a remote, a briefcase type case, a cover and with a variable voltage battery pack. $500. There are other I/Os I haven't tried. The HDMI and component work quite well. I generally hooked the monitor to HDMI and the Nano to the HD-SDI on the EX1.
Sony charger
SxS 8 gig card
original booklet
USB cable
component cable
composite cable
