Sony Optical Out
royfel
I am recording with a Sony PCM-D50 and syncing in post with Plural Eyes to a Pana GH2. One of the outputs in my recorder is a Optical Out spec:
Line Output (Optical) : Output imped: 220 ohms, Load imped: 22 k ohm. Digital = Output level: -21dBm to -15 dBm What sort of cord or connection would I need to connect this to the camera?
Why do you want to connect to camera if you're syncing in post?
Not sure the GH2 has optical (which I doubt it does)
That's a combo out. It's both an analog line (1/8" TRS) and an optical connection. SONY has used those since the days of portable/Walkman DAT and MiniDisc.
If you're wanting to feed the recorder to the camera during production for better reference audio, simply use an attenuated 1/8" cable.
