NC17z
SOLD
Friend and Colleague has a mint condition Sony NX5U professional camcorder up for sale - $3250.00. The camcorder is very lightly used as it has 2x10H (Total Time of USE) on it. It was mostly a balcony camera at weddings and as soon as I opened the box I put on a clear u/v filter on it to protect the lens. Their are no wear marks at all. I still have the original box and paper work from B&H Video. The NXCAM comes with a NP-F970 Battery (upgrade), remote, charger, cables and the Tiffen u/v clear filter. This camcorder has been babied its whole life. This is a great camera, but I am shooting mostly DSLR now, so it is time to let her go...It's currently out of stock at B & H, so buy it NOW!
B&H Description:
The first in Sony's line of NXCAM solid-state camcorders, the HXR-NX5U is also the company's first professional-level AVCHD camcorder. And while it may look similar to its HDV predecessor, the HVR-Z5U, in fact this is a very different animal. Its ability to capture HD and SD video in AVCHD and MPEG-2 formats--and save it to solid state media--is only one of its distinctive traits. Full-raster 1920 x 1080 video is another, including the option of recording 720/60p video as well as 60i, 30p and 24p. And because the NX5U can capture to media cards plus an optional flash memory unit, you can simultaneously record a different signal to each, whether HD + a backup or HD + SD. The footage is then easily downloaded to a computer or backup drive using USB 2.0.
Three 1/3" CMOS Exmor sensors, a 20x 'G' lens and dual XLR inputs are carried over from the Z5U, but the beautiful video and audio these elements produce are now in service to a higher level of professional control. An HD-SDI output makes this one of the most affordable camcorders to provide uncompressed 4:2:2 output, while HDMI and RCA outputs allow for connection to professional and consumer-grade monitors alike. Timecode sync between two or more cameras is also possible, and the addition of GPS technology makes for another first on an AVCHD pro camcorder.
Meanwhile, a newly designed user interface--including convenient MODE buttons and a touch-screen menu--make setup and operation easier than ever. And if touch-screen controls aren't your thing, there are the usual navigation keys and thumbwheel to help get you around. Whether you're recording at one of the camera's four bit rates (24/17/9/5Mbps), taking advantage of simultaneous or relay HYBRID capture, or recording AC-3 or linear PCM audio, the HXR-NX5U gives you near-professional flexibility and control on a prosumer budget.
B&H Description:
