Demistate
I just got my a7s in today and i'm running some tests to see how it differs from the Sony FS700. As I find more things i'll update this first post:
- Rolling Shutter is worse on the A7s in Full Frame mode.
- Slog2 on the A7s records in TV safe levels (16-235) while slog2 on the Fs700 records to the entire RGB range (0-255) I'm still investigating this.
- Cine1 and Cine 4 will record to the entire RGB range on both cameras. (0-255)
- If the viewfinder shows Zebras (even at 100+), there is still detail behind there in a Raw photo.
- Don't shoot still photos with the Slog Profile. It puts the camera in ISO3200, and way underexposes the image requiring you to bring it up in Adobe Camera Raw by about 2.5 stops. This Looks worse than the same picture auto exposed at ISO 100, no picture profile
- I bought a 67mm Tiffen Variable ND for shooting outdoors and maintaining a 1/50th of a second shutter speed (you can't do 1/48th like the FS700 :~() It is not enough ND to keep clouds from peaking on a sunny day (100+ zebra) even with max ND in slog 2 mode.
- Knee and Black Level do not affect the image in Slog2 on the A7s. This is also true for the FS700.
- Black Gamma does however affect Slog2 Profile in the A7s. Mostly the lower 40% of the signal
- 24P and 30P modes are downsampling from the full 4K sensor, 60P and 120P do not, and will have aliasing.
- I'm seeing a green color cast in shadows on the A7s, while I see a magenta color cast in the shadows on the FS700. This explains why Film emulation luts that contain both Slog2, and Slog2 -- FS700 profiles are almost the same but have more/less magenta in them.
