If you were shopping for a camera that was not destined for making one's living, which of the following would you consider:
Sony FS5m1 hopefully with the raw upgrade already installed.
Z Cam E2-M4.
Yes I know the Z Cam needs expensive drives, but all the good resolutions need a USB C SSD anyway so I don't consider C Flash part of the package.
My lenses are all FD converted to passive EF, so the mount doesn't matter too much. I do have EF to m43 adapters and a focal reducer already being used on GH2 cameras. Just looking for an upgrade that will be easier to work with, that stupid AC3 audio makes me convert everything before I can bring it into Media Composer or Resolve and I'm tired of the extra step.
No I do not currently have a recorder to handle the RAW out of either camera, but I do have a 3G Video Assist SDI/HDMI monitor for use with the Z Cam.
I'm mostly thinking out loud and watching auctions to try and grab something cheap, and I keep going back and forth on these two cameras. I might consider an E2 with the permanent m43 mount, but the -M4 would be better so I can change the mount if needed/desired. They are also rumored to be making an EF mount with focal reducer built in, and since they use locking EF mounts, this would be a big advantage for me being much more robust.
The FS5 with a speed booster would give me some very wide angles to use, widest lens in my kit is a 15mm and I go up to 200mm (including two parfocal zooms) all f2.8 or faster (except the zooms at f3.5).
Right now I have no needs beyond 1080, but having more/better and better noise at higher ISO would be great once in a while.
Z Cam E2-M4.
