Wow, seeing that purple Miranda brings me back!
If you can't that to work, this will do it:
https://www.amazon.com/Blackmagic-D...ocphy=9031167&hvtargid=pla-349043990564&psc=1
Ok, thank you, will do I switched the dip switch to the left as instructed, so i'll try this converter option, which cables do I need for the blackmagic converter?
.Remember the little "mini" Miranda that bolted on over top of the side mounted analog component outs?
(UPDATE) OK I switched to the HD-SDI to cam and that worked! so I have a signal but now its just a black screen
I was able to grab a signal by switching around the dip switches, now its just a black screen in the atomos, So im assuming I have to hook the bnc components to a monitor for picture and sending another cable via atomos to that monitor? or is it some other some configuring with the camera?
