[FS: General] Sony F35 with 7Q - Painted Black
yachacha
I have for sale Sony F35 painted black. It is rubberized truck bed liner, looks great in different light and hides scratches. It's not perfect but it is the 3rd F35 I've painted so I think 1 of 3 Black F35's out there. This F35 was a F23, I was lucky to get 2 new looking F35 optical blocks a few years ago so the most important piece of the camera has previous low or no use.
I made the PL Lens ring by converting a Sony E Mount PL adapter. It does not have the issue of tabs bumping into lens that the Sony PL Ring does so this can accept a wider variety of lenses. The normal solution for F35 users is to remove the PL ring tabs completely from the ring, with this ring you have the smaller tabs that do not get in the way of any lens.
The top dock has been removed and replaced with custom cheese plate. This plate was professionally made by a camera house, it is the correct angle to make the top of the camera flat. I will include all the parts of the top dock if you ever want to put it back on, it is simple process and 8 screws.
Clean IR Cut Glass. Backfocus set. No dead pixels. New firmware reset. Dual link 12-bit through IF box works. 50p works. Audio input works. All ports work. Everything you need minus lens.
-Sony F35 Black
-IF Box with Gold Mount Battery Plate
-7Q with correct firmware loaded
-2 x 512gb 7Q SSD's
-Zacuto VTC Shoulder Mount with VTC plate
-2 x 130wh Gold Mount Battery with Dual Charger.
Lots of small parts: 7Q Dtap, 7Q Nato Rail with 15mm rod mount, SSD USB3 reader, 7Q hard case, 15mm rods for Zacuto, 4 x thin BNC cables, F35 short DTAP, F35 long DTAP. 4 pin XLR power cable to power camera from battery charger. The 7Q needs new screen protector I have ordered one I will include.
$5500 plus shipping.
I also have another F35 not painted yet with Sony made PL mount if you would prefer. I am going to sell one of these 2. I am uploading a bunch more photos to album.
