SONY F35 Shutter Speed!
Edrafennas
Hi all , I again ! I have a question ... what shutter angle using? 180* on the Sony F35 seems very smooth ! a feeling that watching movies 60p .
Hi,
Your question is phrased in a confusing way... but it sounds to me like you have a setting wrong somewhere. 180 degree shutter on the F35 is not smooth - it feels exactly like it should.
Perhaps you are in 50i instead, or maybe you have the shutter off?
James
Hi,
James
when he worked on the F23 had very different feelings from 180 degrees = (all settings are correct .
It should look the same - it won't look identical because the F23 will not have the same DoF, but movement on the F35 is perfect. Both are Sony CCD.
Can you post an example?
I am living in Yakutia, injection materials takes a couple of days I = (I think I suspect case in atomos Samurai as on srw1 okay. Sorry, Google translator =((
Russia - amazing
I think try shooting then at 144 degree shutter
yes it does feel different than CMOS shutter cameras - feels smoother than red one mx - less stacatto (google translate that :) )
