I have used it on the Sony SR-R1 SR Memory Recorder.
I am looking to purchase a Sony SR-R1 for my F35 as I think it is the best fit to acquire the highest quality recording out of this camera.
I am curious to hear what your thoughts are on this recorder as you have used it before with the F35. Also, is the cheapest way to offload the media to a computer through the $2500 SR-D1 reader?! This is the only thing putting me off on buying this recorder. It seems ridiculously expensive. Did you use this reader to transfer your material? If so does it simply connect to a USB port on the computer?
Thanks for your help Viddovation.
Igor
The 7Q is just like gemini, doesnt generate timecodewhich is a turn down for long term productions
I got it off ebay with two 256GB cards
With all due respect to Mitch though, I'm not a fan of their licensing pricing structure, and I particularly would be cautious about buying any kit today based on features that are "on their roadmap."
How often you have to offload with such small capacity media? 50p probably goes through it like butter right?
Well the O7Q base is only 1080p 10bit 422 YUV. That's what I gleaned from their webpage. For the FS700 1080p 12bit RGB 444 and 10bit YUV 50p/60p 422 is part of the $795 paid featureset currently labeled as "Sony". So, I don't expect they'll let you use it for free...
A fair question. The cards are good for somewhere around 36-40 minutes of 12bit RGB 444 and 77minutes of 10bit 422 footage, depending on the exact codec used. In practice, I found two cards sufficient to get through a 12 hour feature day, generally. We'd swap the cards at lunch. Mind you, that set it was important not to run out of media, so I convinced the production to rent a third card. We hardly used it, but it was good peace of mind.
