[FS: General] Sony F35 - $3800
yachacha
Sony F35
Hours:
2.12 Last Firmware
SLOG 1 SGAMUT
12-bit 444 output
Back focus adjusted.
No Dead/Stuck Pixels.
Fans cleaned and very quiet.
The IR glass is flawless, no cleaning scratches.
I have worked with quite a few F35's. This one is very clean. I will guarantee it to arrive in complete functioning state.
IMG_2491.jpgIMG_2492.jpgIMG_2494.jpgIMG_2495.jpgIMG_2505.jpgIMG_2506.jpgIMG_2507.jpgIMG_2508.jpgIMG_2509.jpgIMG_2510.jpg
Parts Included:
-IF Box with 12-bit 444 output
-Anton Bauer Battery Plate mounted to back of IF Box.
---Power run through IF Box, no external battery cable.
-Quad D-Tap splitter for EVF/Recorder.
-Factory Top Handle
-Bottom Riser Plate (you need this for 19mm Rod plates to be at correct height)
Total $3800
Shipping is $50 for USPS Priority Mail. I can package very safely.
Most HDSDI EVF's will work with the camera.
I strongly recommend using Convergent Design 7Q, it works with 12-bit modes and also the 50P both are unique on F35 because they are sent over dual link SDI. Convergent Design worked with F35 specifically to make sure everything was correct including the need to record 104% Data Range when the camera is in SLOG and some of the Hyper Gamma's.
10-bit 422 is ez and cheap.
There will never be a camera like the F35 again. Every camera produced today is a profit model. When Panavision and Sony sat down to make the F35, the only consideration was how can we replace film with a digital camera, they thought it would work for 10+ years. Only about 300 of these ever produced.
