Sony F3 3g Port
Bertel1986
Hi, i would like to know,which is the 3g Port on my Sony F3.
I tried Port A and B,but when i turn on 3g 444 the picture becomes a yellowish look.
My understanding is that the 444 is RGB, not YUV. Are you sure that the device you've attached is RGB compatible? What's your cable path?
I just got the new PVM-1741 OLED monitor, and for yuks turned on the 3G S-Log output.
I was getting purple and green image, much like the monitor was expecting 444 YUV and was getting RGB (which the monitor status confirmed, RGB)
Wonder what's up?
Must be broken, so you have to give it to me ;)
Have you tried a dual link output? Or have you tried just 3G RGB 444 (no s-log)?
Ned Soltz
Wonder what's up?
have you tried it at 29.97 or 60p? or was it just a 23.98 psf? try it at the other framerates if you can, and see if you still have the same problem... and have you tried it dual link opposed to 3g? sometimes 3g can be a little bit of a drama queen.
