Bassman2003
I think in a compressed environment, the cleaner the signal you can send though the encoder, the better chance the encoder has.
The detail settings in these cameras really turn out to be more edge enhancement than enything else. The amount of detail is captured by the sensors.
I have had the best results with turning down detail quite a bit which reduces noise in the image and sharpening pretty heavy in post.
The advantage being that the software sharpening has much more processing power at its disposal and it will approach the entire image rather than just the edges.
I use Edius and am amazed at how much clean detail can be found using this method. This has worked best with Panasonic cameras but applies the the EX-1 as well.
