Richard Allen Crook
I want to use my Sony NEX-5n as a "b-cam" to my EA50. I decided to match picture profiles so they edit together seamlessly. First some of the differences between the two cameras.
1) Resolution. The resolution between the two cams is identical. I don't see any "extra processing" done in the EA50 over the 5n.
2) Noise. They both have the same bitrate (28mbps) and the artifacts and noise levels are identical (with matching profiles).
3) Field of View. The 5n has a wider field of view. Super 35mm vs APS-c.
4) Native ISO. The ISOs are identical in brightness.
5) Dynamic Range. It looks as though the 5n actually has about 1 stop MORE dynamic range. But this is ONLY BECAUSE we can adjust the gamma curve differently than on the EA50. When you go -3 on contrast on the 5n, you are flattening out the gamma curve, pulling more information off the sensor than you can on the EA50, which does not have this feature. You can adjust the top and low ends (knee and black gamma) but you can't actually flatten it out as much as the 5n, giving the 5n an edge in this area.
6) Record Times. The 5n OVERHEATS after only about 5-10 minutes of continuous video recording. I actually place a Radio Shack fan on the back of the camera and the problem went away. But even with the overheating problem solved, you still only get 30 minutes of continuous shooting before it stops recording.
7) Tools. The 5n does not have zebras. It really has just about all the other visual tools that the EA50 has - including peaking, histogram, focus assist. The 5n also has a meter that is common on still cameras which the EA50 does not.
8) Ergonomics. The ea50 wins all across the board. Actually it's better than the Red Epic, Sony Fs100/700, and F3/F5/F55. Perfect size/weight for run n gun shoots plus the eyepiece is in the right place without all the rigging necessary for other cameras.
MATCHING THE PROFILES:
I wanted a profile that requires some minor grading in post and also perfectly match the two cameras. Here are the profiles:
Sony NEX-5N
Profile: Standard
Contrast: -2
Saturation: -1
Sharpness: +1
Turn off HDR
Sony NEX-EA50
Black Level: 0
Gamma: ITU709
Black Gamma: Low, +7
Knee: Manual, 80%, -3
Color Mode: Standard, 8
Color Level: -1
Color Phase: 0
Color Depth, All 0
WB Shift: All 0
Detail: +3, Manual On, Type3, Limit 7
Sony NEX-5N
Profile: Standard
Contrast: -2
Saturation: -1
Sharpness: +1
Turn off HDR
Sony NEX-EA50
Black Level: 0
Gamma: ITU709
Color Level: -1
Color Phase: 0
Color Depth, All 0
WB Shift: All 0
