imtinc
$1895
This Sony RX1 is in pristine condition and looks brand new. In addition to the Camera, the bundle includes two batteries, the FDA-EVM1K Electronic Viewfinder, Heliopan 49mm UV SH-PMC Filter, Heliopan 49mm Slim Circular Polarizer SH-PMC Filter, original box, , USB cable, manuals, etc. A street, travel, family, and nature photographer's and/or videographer's dream, this full frame, high-end camera feels incredible in the hand and yet looks inconspicuous and non-threatening.
The camera sells at B&H for $2800 (http://www.bhphotovideo.com/c/product/891105-REG/Sony_dscrx1_DSC_RX1_Full_Frame_Point.html), the electronic viewfinder for $450 (http://www.bhphotovideo.com/c/produ...K_Electronic_Viewfinder.html/pageID/accessory), the UV for $70 http://www.bhphotovideo.com/c/product/302204-REG/Heliopan_704911_49mm_UV_Haze_SH_PMC.html, the Polarizer for $150 (http://www.bhphotovideo.com/c/product/351328-REG/Heliopan_704940_49_mm_Circular_Polarizer.html).
PRODUCT HIGHLIGHTS
Full Frame 24MP CMOS Sensor
JPEG, 14-bit RAW Image Capture
35mm f/2.0 Carl Zeiss Sonnar T* Lens
Xtra Fine 3" LCD Display
Full HD 1080p Video at 24 or 60fps
High Speed AF
Dedicated Focus, Iris and Macro Rings
Full Frame 24MP Bursts at up to 5fps
Hot Shoe for External Flash, Viewfinder
Auto HDR Protects Highlight and Shadow
The Sony Cyber-shot DSC-RX1 Full Frame Compact Digital Camera is the world's first fixed-lens digital camera with a full-frame sensor. This large 35mm Exmor CMOS sensor enables DSLR-quality imaging in a point-and-shoot form factor (4.5 x 2.6 x 2.8" / 11.4 x 6.6 x 7.1 cm). In addition to 24MP JPEG or RAW still images, the RX1 will also shoot Full HD 1080p video at 24 or 60fps. The 35mm f/2.0 Carl Zeiss Sonnar T* lens features a wide maximum aperture of f/2.0 with 9 iris blades, for reliable low-light performance and shallow depth of field with attractive bokeh (background blur). The multi-layered T* coating minimizes ghosting and flare caused by light reflection.
For framing and playback, the camera features a large 3" Xtra Fine LCD monitor with a 1,229k-pixel resolution. The screen uses WhiteMagic technology to improve visibility in bright daylight.
The RX1's sensor works with the BIONZ image processor to enable the camera to autofocus at high speed. Manual focusing is also available, and the camera has three distinct manual control rings for aperture, focusing, and macro.
The combination of the CMOS sensor and the BIONZ processor also allows for improved sensitivity, resulting in better low-light performance. The maximum selectable ISO setting is 25600, enabling low-light shooting without the camera's built-in pop-up flash. Also aiding you in darker conditions is Optical SteadyShot image stabilization, which enables clear, blur-free photos and video. SteadyShot also helps to eliminate motion blur when your subject or the camera moves during image capture.
The RX1 is capable of 5fps high-speed continuous shooting at full 24MP resolution, allowing you to capture fast action sequences. A multi interface hot shoe gives you the ability to attach optional accessories like an external flash unit or electronic viewfinder.
Auto HDR captures a greater dynamic range, combining the best highlight detail from one shot, the best mid-tones from a second, and the best shadow detail from a third into a single image.
Full Frame CMOS Sensor
The RX1 is the world's first fixed-lens digital camera with a full-frame sensor. This large 24.3MP 35mm Exmor CMOS sensor enables DSLR-quality imaging in a point-and-shoot form factor (4.5 x 2.6 x 2.8" / 11.4 x 6.6 x 7.1 cm).
Fixed Carl Zeiss Lens
The camera is also equipped with a fixed Carl Zeiss f/2.0 Sonnar T* lens. The lens features a wide maximum aperture of f/2.0 with 9 iris blades, for clearly-exposed images in low-light conditions and shallow depth of field with attractive bokeh (background defocusing). The lens's macro capabilities allow focusing down to 5.5" (14 cm). A premium multi-layered T* coating also reduces ghost and flare caused by light reflection.
JPEG and RAW
The DSC-RX1 saves pictures as compact JPEG files and/or 14-bit RAW files. RAW files save images prior to de-mosaicing, white balance, sharpness and color enhancement. This retains maximum latitude for enhancing the image in post.
3" Xtra Fine LCD Display
The 3" Xtra Fine LCD Display features 1,229k-dot resolution, and WhiteMagic technology increases visibility in bright daylight. Brightness Control: Auto / Manual (5 steps) / Sunny Weather mode.
Full HD 24p Video with Manual Controls
The RX1 can record video in Full HD 1920x1080p at 24, 25, 50 and 60 frames per second. Also records in 1080i. You can capture 1440×1080 video at 30 or 25fps, as well. Bit rates are as follows: For AVCHD: 28Mbps (1920×1080, 60p/50p), 24Mbps FX (1920×1080, 60i/50i), 17Mbps FH (1920×1080, 60i/50i), 24Mbps FX (1920×1080, 24p/25p), 17Mbps FH (1920×1080, 24p/25p). For MP4: 12Mbps (1440×1080, 30fps/25fps), 3Mbps VGA (640×480, 30fps/25fps). Video features include manual controls, an audio input jack and a multi interface shoe for mounting an external microphone or other accessories (sold separately). Manual Exposure, Program Auto, Aperture Priority and Shutter Speed Priority exposure modes are also available for photos and video. Sound recording and playback are possible via a built-in stereo microphone and mono speaker.
High Speed AF
Autofocus at high speed. To improve focusing speed and sensitivity, the Exmor CMOS sensor uses its rapid throughput to deliver image signals to the camera's BIONZ processor, which provides response data to a new high speed actuator motor in the lens. The result is fast, DSLR-like focusing speeds even in low light.
Three Focusing Modes and Manual Focus Assist
The RX1 features the following focusing modes: Auto Focus (AF), Manual Focus (MF) and Direct Manual Focus (DMF). AF functions as AF-S in still image shooting and as AF-C in video recording. DMF first uses AF to focus on the subject and then enables fast switching to manual focus for precise adjustment. When activated, peaking helps define critical focus by highlighting the edges of objects that are in focus with your choice of three colors (white, red, or yellow). AF Modes: Multi-point AF (25 points) / Center weighted AF / Flexible spot / Flexible spot (tracking focus) / Flexible sport (face tracking).
The BIONZ image processor enables up to 5fps high-speed continuous shooting and 14-bit RAW image data recording.
RX1 features three distinct manual control rings for aperture, focusing, and macro.
Low-light Performance
The maximum selectable ISO setting is 25600, which enables low-light shooting without a flash. In addition, DSC-RX1 can capture six images in a fraction of a second and combine the data from all six to create a single image with a reduction in noise equivalent to two additional steps of ISO sensitivity.
SteadyShot Image Stabilization
Optical SteadyShot image stabilization helps you achieve clear, blur-free shots in low-light conditions or when your subject or the camera moves during image capture.
Shoe for Flash, Light or External Mic
The multi interface shoe provides a versatile connection for accessories like an external flash unit, an electronic viewfinder, an optical viewfinder, a thumb grip, a clip-on LCD monitor, an external microphone and more (sold separately).
Quick Navi
Pressing the Fn button activates Quick Navi, which allows the user to check camera settings at a glance and promptly change settings without having to search for dedicated menus.
Memory Recall
MR (memory recall) mode can memorize up to three groups of the user's preferred settings. Settings include zoom magnification, white balance, exposure compensation, shutter speed, drive mode and metering modes. This enables quick switching of settings at the right moment.
Auto HDR captures more dynamic range, combining the best highlight detail from one shot with the best mid-tones from a second and the best shadow detail from a third, for one output shot with up to 6 EV stops in a split second.
D-Range Optimizer
Off, Dynamic Range Optimizer (Auto/Level), Auto High Dynamic Range: Auto exposure difference, Exposure difference level (1.0-6.0EV, 1.0-EV step).
Built in pop up flash
The RX1 has a built-in flash with Auto, Slow Sync, Rear Sync, Fill-flash and Flash Off modes.
Dual Aspect Ratio Recording for Still Images
The RX1 can capture still images in either 3:2 or 16:9 aspect ratios, which allows you to choose a ratio that matches the scene or the specific shooting purpose.
Digital Level Gauge
Makes it easy to level the camera.
Conveniently Placed Dials
The camera features easily-accessible exposure compensation and focus mode dials.
Creative Styles
Control how the camera processes your images with 15 finishing styles: Standard, Vivid, Neutral, Clear, Deep, Light, Twilight, Night View, Autumn Leaves, B&W, Sepia, Sunset, Portrait and Landscape. You can even fine-tune contrast, saturation, and sharpness to your personal taste.
Picture Effect Mode
Picture Effects are a simple way to give scenes a heightened mood and emphasize certain attributes. Effects include Soft Focus, Posterization, Retro Photo, High Contrast Monochrome, Rich-tone Monochrome, Miniature, Soft High-key, Toy Camera, Pop Color, Partial Color, Watercolor Painting, HDR Painting, and Illustration.
Sweep Panorama Mode
Sweep Panorama Mode captures expansive landscapes automatically. Press the shutter and sweep vertically or horizontally, while the camera shoots continuous images and stitches them together.
Intelligent Scene Recognition Mode
Automatically detects 33 different scene types for still images and 44 scenes for videos, then chooses the appropriate camera settings. In Auto Mode, the camera captures a single shot with the optimal settings. In Advanced Mode, it takes a photo with the optimal settings and, in difficult lighting (low light or back light), immediately takes a second photo with another optimized setting--allowing you to choose which one you want to keep.
Face Detection / Registration Technology
The RX1 can automatically detect and register up to eight individual faces and adjust focus, exposure, white balance and flash. This technology can even prioritize children or adults.
Auto Portrait Framing
Combining Face Detection and By Pixel Super Resolution technologies with the rule of thirds, Auto Portrait Framing provides pleasingly composed and balanced, full resolution portraits. When activated, Auto Portrait Framing will save the optimally reframed image and a copy of the original. Landscape orientation is also available.
White Balance Modes
Auto, Cloudy, Custom, Daylight, Flash, Fluorescent, Incandescent, Shade, Filter, Color Temperature
Playback
Still Image Playback Options: Control for HDMI, Slideshow.
Sony - FDA-EVM1K Electronic Viewfinder
PRODUCT HIGHLIGHTS
Compatible with Sony RX1 Digital Camera
XGA OLED EVF with 2359k-Dot Resolution
Adjustable 0-90° Viewing Position
Real-Time Exposure Adjustment Review
Attaches via Multi-Interface Shoe
Adjustable Diopter
The Sony FDA-EVM1K Electronic Viewfinder is an external EVF designed for use with the Sony Cyber-shot RX1 compact digital camera. This 0.5" XGA OLED finder has a 2359k-dot resolution and 100% coverage for high image clarity and detail. The OLED design helps to keep motion blur to a minimum, making it ideal for monitoring and tracking of moving subjects. This viewfinder attaches to the camera via the multi-interface shoe and offers an adjustable 0-90° viewing angle to support shooting from multiple positions.
The benefit of an electronic viewfinder is that you can instantly see the effects of camera adjustments as well as other necessary shooting-related information for an overall more efficient workflow.
PRODUCT HIGHLIGHTS
High Speed AF
JPEG and RAW
High Speed AF
Quick Navi
Memory Recall
D-Range Optimizer
Digital Level Gauge
Creative Styles
Picture Effect Mode
Sweep Panorama Mode
White Balance Modes
Playback
PRODUCT HIGHLIGHTS
Adjustable Diopter
