Sony A7s Metabones or not Metabones?
dsp_418
So, as far as I understand, metabones equipment is meant to help whenever one is working in APS-C mode, is that correct?
If so, assuming I just want to work in FF and I'm only using manual lenses, is a traditional adapter (for instance http://amzn.com/B003ZLISZU) enough?
You are thinking about speed booster, that is not for full frame, either metabones to E mount full frame or commlite latest version, I have both, they both works but both have lights glare depending on what lens you are using, I would go with commlite since it is a lot cheaper.
Thanks PSA1,
I'm looking at the commlite right now, it seems the main difference with other cheaper adapters is the auto focus function that I don't need it.
If it's just that I guess I can save money and go with just the simple version with no auto-focus feature.
Metabones have no auto focus either at least for professional, just read it on their site, focus is really slow, hunting forever and most of the time it is not right.
Today I bought metabones III but are not happy with it, I put a Canon 24-70 II on it and not working aperture After some installation and removal began operating. mounting the device does not block as lens, having to press button unit to give it jos.doar rotate the lens and comes down
I have a question, I put the adapter on Sony A7s.Dar CamDate metabones reaches the end of the rotation, it locks me on camera as the lensnamely, to give the lens off A7S need to disconnect button but AC coming off that easy just by turning it and it's not necessary to press the button on A7S, so is the will? have to push harder adapter assembly to pass block on A7S??
