bytehoven
For Sale: (1) Tempo-x SATA 4+4 Sonnet Technologies 8-Port ATA PCI-X Host Controller. (not eSATA)
PCI-X and PCI slots for Mac G3 (blue & white), All G4 except the Cube, all G5
Asking $75 shipped and can take paypal.
I have many SATA<->SATA cables available for internal & external connection. Please let me know what cables you might need and I'll see what I can include in the deal.
Affordable solution for adding four external and four internal SATA ports to your computer
3 Gb/s SATA II host controller
64-bit, 133MHz PCI-X Serial ATA host controller
48-bit LBA support for drives with a capacity larger than 137 GB(1)
Spread Spectrum Clocking for compatibility with all SATA drives
Hot-swap drive support (2)
Mac Compatibility
Power Mac® G4 ( with PCI or PCI-X slots)
Power Mac G5 with PCI slot or PCI-X slots only) (3)
Mac OS X Version 10.2 or later
Windows Compatibility
PC (with PCI or PCI-X slots) (2)
Windows XP SP 2 or later (2)
Technical Specifications
Part No.
TSATA-4X4-BLT Rev C
64 bit, 133MHz PCI-X; 32-bit PCI bus 2.2 Compliant
External Connectors - Four SATA
Internal Connectors - Four SATA
Drives Supported
Up to 8
Data Transfer Rate
Up to 300 MB per second per port
ATAPI Support
No
Drive Type Supported
Serial ATA I & II; Ultra DMA 133/100/66/33 (parallel) (3)
Firmware
Flash-ROM upgradeable to latest firmware version
Advanced Features
* True plug-and-play; no device drivers to install
* Deep sleep support
* Hot-swap drive support
* Spread Spectrum Clocking for compatibility with all SATA drives
* Bus Mastering frees CPU from data I/O handling
* 48-bit LBA support for drives larger than 137 GB
Mac Compatibility
Part No.
TSATA-4X4-BLT Rev C
Drives Supported
Up to 8
Data Transfer Rate
ATAPI Support
No
Firmware
Advanced Features
