Thomas Smet
Welcome to the optical illusion known as interlaced. I have always considered interlaced a form of video compression sort of like compressing color down to 4:2:0. Yes you only have 540 unique vertical lines but because they are recorded every other line it sort of gives an optical illusion of 1080 lines because of how they are spaced out. Our eyes look at this single field and sort of the way our brains fill in the gaps between 24p frames our brains fill in the alternate lines. When you play this at 60 fields per second the optical illusion is even better.
This is all in theory of course. The reality is that this type of video doesn't compress as well and 4:2:0 color is putrid with interlaced video. For real world objects with lots of filtering interlaced still works very well but as soon as you have slight horizontal angles and thin lines this form of compression can fall apart. Sort of like 4:1:1 looking fine until you have a rich difference in colors.
So just think of interlaced as a sort of video compression where vertically you have a situation sort of like chroma subsampling that also affects the luma. Every other 1/60th of a second alternates vertically by 1 pixel. If both fields were the same then you really would have 1920x540 resolution with much more evident gaps in fine details.
