Playback:
I installed Haali splitter to treat MPEG TS container and ffdshow for decoding. This combo is universal, independent of any other players, codecs, and sufficient for playback in any application that uses DirectShow.
Pulldown removal:
NLE-agnostic method - AviSynth + VirtualDub.
I created script (simple text file with .avs extension, notepad will do the job):
DirectShowSource("filename.mts").AssumeTFF().DoubleWeave().Pulldown(0,2)
It opens video via DirectShow, assumes that top field is first and removes pulldown. You can drop it to VDub and transcode with any VfW codec into .avi. Most transcoding programs (procoder, avidemux ...) will accept it, too.
Edius (ver. 5.1) way.
I used free utility - AVCHD converter made by Canopus/Thomson. It converts .mts AVCHD to CanopusHQ. Just select files you need in Explorer/Total commander, click RMB, select "convert with AVCHD2HQ" (this menu item appears after utility installation). You can configure it by starting the AVCHD2HQ utility itself. BTW, it also can recompress .mts into HDV/MPEG2, but AFAIK it requires Edius anyway, so it won't be a standalone solution.
Then I started new Edius project - 1080p23,98 and threw in .avi files. Edius is smart enough to remove pulldown.
NB: project must have _23,98_, NOT 24 framerate, or you'll get some ghosting artifacts.
Hope it wil help.
Pulldown removal:
Hope it wil help.
