That´s odd. In this document the knee slope is the exact opposite. Minus = steep and plus = gentle
I believe the idea is you want to control the INTERSECTING point to the horizontal line. You're controlling how much illumination (X-Axis) you are getting WITHIN the confines of your white clip point (Y-Axis).
So find your Y-Maximum then adjust your horizontal movement along that Y-Maximum. So in the example Y-Maximum = 109%. Then that becomes your Y-Constant (Y-Maximum = Y-Constant). Now as you adjust your slope it will intersect at various points along that Y-Constant.
We are essentially constraining our equation (the slope) along that Y-Constant (White Clip Line) so that we get a White Clip Point (hence the intersection).
I think the trick is finding out how Sony has calibrated the knee such that where Knee = 0.
EDIT:
Some things that caught my eye (I'm hypothesizing here as I'm no expert):
- Sony notes that this is a proprietary implementation as Sony explicitly notes that this is only on "Sony Cameras" so other Knees use different equations.
- The main thing Sony wants you to know is that an INCREASING Knee value extends the use of the video camera's dynamic range. Sony managed to increase the dynamic range through COMPRESSION. So as Knee increases so does the dynamic range of the camera BUT only through compression so things like noise should be taken into consideration.
- Sony notes that as Dynamic Range of the camera increases, the risk of getting a washed out image also increases.
- Therefore the opposite is true, a lower Knee value decreases dynamic range but also decreases noise and colors should look more full as there is less risk of being washed out.
- The document also recommends the complementary aide of the "Knee Function" and "Knee Saturation" function. So what this tells me is that they've applied a similar Knee Function (equation) to other aspects of image quality to help aide the use of their knee for dynamic range. Kind of like a drug to aide in side effects of other drugs. Anyone see these complementary aides on the FS100?
QUESTION:
- How does Knee Point relate to Knee Slope and the White Clip Point?
QUESTION:
