'some clips need repairin. Play clips to be repaired' error message.
Sparky874
Hello all.
Everytime I go into the menu to review my clips, I always get this message about some clips needing to be repaired. Does anyone else have this message? But they seem to be okay when I play through them. Now I always carry my laptop with me and transfer the clips over over to it on a regular basis for back up purposes. I then store them long term on XDCAM Blue ray discs. I use Sandisk extreme 32 gig cards in the camera. Has anyone else had a similar problem?
Thanks, Sparky
Then you should have your camera checked. This is not normal performance. And have your cards with you when you take it in. I am assuming that you bought these cards from a reliable source like a B & H. If from Ebay, they could be questionable. Lots of SD Card scams out there right now. Check to see if you can do VFR recording on them.
Best,
jan
Bought them from a good retailer in the UK, H Preston's. I can do VFR recording as well without any issues.
Then I think you should have your camera looked at. Something isn't right. Have Panasonic take a look and take your cards with you.
Best,
Jan
