I may piece meal out a Solid Camera double lock system, if a couple of buyers are interested in the specific FS100 pieces. Everything 35% retail price listed on Solid Camera's web site.
-Top plate, with inline handle. This is a great plate to mount gear, especially if interested in Solid's excellent EVF mount. Specific to FS100 $288.60
-Sony E to PL mount. Superb machining. You can purchase the 15mm rod adapter from Solid to use with any E mount camera, at the proper rod/lens height of course. You must see the rod mount on Solid's site- sturdiest on the market. $516.75
-FS100 Cine Base adapter $168.75 Solid makes adapters for the F3 and AF100. 16x9 has adapters for the FS700
-baseplate system with 15mm rods. Solid makes risers for other cameras, and as you can see, the base was designed for and is also sold by 16X9, Inc. So any riser from 16x9 or Solid that is designed for this sliding base will work. The sliding base is sold as an assembly, can't sell the dovetail separately. $633.75 This has to sell last.
-Double lock mount. For the FS100 or FS700 or any other camera Solid Cam develops the pieces for. $321.75
Again, most of the pieces will need to be spoken for before I'll break it up- but is it possible.
If interested please contact direct at karlkimdp@gmail.com
