Software/plugin for moves on stills?
take2visualmedia
I have an upcoming project that will require a good mix of stills and video. I typically manually do moves on stills in FCP or AE using key frames. This is a long, time intensive process.
Is anyone using any software out there that allows you to pop in a photo and it gives you choices on moves etc?
David, quick question....
I downloaded the demo, what do you do (settings wise) to get the slideshow into FCP? I tried custom settings using the QT option but the results were less than stellar.
What custom setting did you establish in the export including codec and frame size, and what sequence settings in FCP?
I used animation codec at 960x720 (to match sequence) didn't look great. Also the demo I downloaded is standalone but the web page shows the program within FCP. I emailed Boinx for more info....
For any type of still work, Fotomagico is the easiest to use program.
FCP just doesn't cut for movement on stills, and while FXFactory and others have plug ins, the interface of FCP doesn't lend itself to good pan/zoom work.
My opinion at least.
