Smooth Shooter/ Glidecam 4000
AbracadabraFilms
I just took delivery of a Smooth Shooter and Glidecam 4000 yesterday. I thought I'd post my initial comments. It's an amazing product for the price.
The Glidecam 4000 is shipped disassembled but the assembly procedure is a snap. The Smooth Shooter vest and arm are very easy to configure as well. I'm using the rig with a DVX100a fitted with a Sennheiser ME66 shotgum mic with fuzzy and wireless transmitter. Also, I have a dimable Frezzi light mounted atop the camera as well. The power for the light comes from an NP1 NImh battery in a plastic battery box mounted with 2" velcro to the botom of the Glidecam 4000 weight platform. This also serves as a counterbalance weight. Fitted on the DVX100a is a Sony .8 zoom through wide angle adapter which weighs about 1.5 lbs. That lens is the accessory WA adapter from the Sony Z1U.
That said, it took less than 1 hour to achieve proper balance of the 4000. The directions are straight forward but it is important to follow the procedure. All of the horizontal balance adjustments were made on the sled. It's important to note that even a 1/16 move on the sled adjustment will make a noticeable difference. I used a Bogen quick realease platform to attach the camera
http://www.bhphotovideo.com/...e=categoryNavigation
This is an absolute must as one will loose all adjustments taking the camera on and off. Get 2 and put the other on your tripod so you can easily switch the camera back and forth.
Common sense will help you establish the starting point for mounting the quick release to the sled. In this case I knew that the camera was very nose heavy from the WA adapter and light, so I started with the camera pretty far back on the sled. The fine adjustmenst are done with the thumb screws on the sled.
The only tricking part was achieving the correct top to bottom weight. It's called the drop test and it's in essence how close the top is in balance with the bottom from the center point. This was easlily done by adding one more weight plate to the top sled and lengthening the lower unit adjustment.
Another must is a C stand to hold the rig when not in use. It wouldn't make sense to lay it down.
The entire unit weighs about 15 lbs. The Smooth shooter arm and vest with the two springs intsalled can handle 18 lbs. In fact it is suggested that you weight up the unit to take advantage of the "mass" factor. "An object at rest tends to stay at rest and an object in motion tends to stay in motion with the same speed and in the same direction unless acted upon by an unbalanced force." The more mass, the more resistant to jiggle.
After mounting the assembly to the vest and arm, I was amazed how stable the camera is. It does remove shakes from walking and it does create a very smooth gliding motion. It's going to take some practice to learn to control framing, but overall I am very pleased with the product and performance.
It's made very well, very professional ad looks to be very durable.
It's a definate winner, I think that I can wear the rig for long periods as I didn't feel much fatigue. The vest can get warm in 80 + heat. BUT...I can't imagine using the 4000 without the Smooth Shooter for anything bigger than a GL2. I work out, and could never hold a 15 lb unit in front of me very long. But with the vest and arm, it's literally weightless. In fact visually, it looks kind of creepy how it just seems to float in space.
Thanks Abra:
This is the toughest purchase and your review helped.
Does the 4000 do lowmode without an optional adapter? According to BH Photo "You can shoot upside-down, sideways, low near the ground, overhead and angled, as in a Dutch shot." Just looking at the unit, I can't see how the unit can be used low, even with an adapter.
If you could report on the 4000's low capability, I'd appreciate it. How low is low for the 4000?
I need to do extensive low shooting and I'd rather the 4000 over the Flowpod.
Moe:
You have touched a tricky area with the Low-mode.. this is one example where many cheaper rigs come up short. Unfortunaly including Glidecam.. They don't do low mode very well (at all really) with the 2K or 4K - therfore the smooth shooter. It's a more advanced feature that this rigs arn't really tageted at. B&H's description is only regarding the CG 4K on it's own - which you can do low mode with if you hold the gimble handle upside down (risky)
This is one of the features that you will only find in more expensive rigs. see my post here: http://www.dvxuser.com/V3/showthread.php?t=36827&page=3
John:
Think carefully about the Basson.. they may have features, but there have been issues with quality in the past, read this thread (on yet another forum).. http://www.steadiforum.com/showthread.php?t=504
I, too, purchased the SS w/the GC4000 a few months ago. As was said earlier, balancing is crucial. I have found the vest to be very warm after a period of time depending on how much work you are doing with walking, running, climbing stairs, etc. I can see why Steadicam and GC operators sometimes wears a towel around their neck so as to wipe the sweat off from time to time. As with most things practice makes perfect. There is a forum over on the Glidecam website where questions can be posted on all of the GC products. There isn't that many postings yet so I can assume that the forum is fairly new.
I can't see how it can go in a low mode, other than upside down. It can be encouraged to go lower than center. Hope this helps....
That looks like a very nice rig. A bit more money of course. The is also an Ameerican company called Animagique who makes a MagiCam. I have no info about their product or service. I understand that it's very good with heavy cameras.
I agree with you Mikko, the Flyer is certainly a more sophisticated product hence the price. You get what you pay for. My budget kept me under $2,000, so the SS was the best choice I could make. Perhaps if need requires and when I get more experience with a stabilizer rig, I could rent a Flyer. You bring up a good point about the internal wiring. As mentioned, I have an NP1 in a case I fabricated under the weight plate of the GC4000. It's working out great...in fact they should offer it as an option. The caveat is that the wire must be velcro tie wrapped to the post. Thanks for your Flyer review BTW. I read it before I decided on the SS.
