SmallHD dp6 problem
Geesbert
is it normal, that it takes up to 10 seconds for the DP6 to show a picture when I switch from slowmo to regular an back? it's the HDMI only version, is this better on SDI?
10 seconds I would say is not normal. On my DP6 (HDMI only as well) I have a connection drop of maybe a second or two when switching between super slowmo to normal framerate. It simply takes that time for the monitor to sync to a change in signal output.
Do you have the latest firmware on the DP6?
Did you try different HDMI cables?
Did you try changing HDMI output settings in the FS700 menu?
Any of these could be the cause of problem, so I would suggest you test them out one by one.
Do you see stuterring on the DP6 on fast pans when you set the camera to 25P?
I have this problem and they replicated it at SmallHD but without any solution.
So it must be only on the SDI/HDMI version or maybe the F3 signal doing that.
Here's what SmallHD replied back then:
> Got ours to do that as well I showed our firmware guy and asked him to look into it for a future firmware update it is really faint though it took me a while to notice it (and they had an F3 so thay replicated the problem)
You mean that judder effect on vertical lines, especially noticeable in high contrast scenes? If that's so, I'm afraid that is not an issue with DP6, but rather with all digital cameras. It's called motion judder, and depending on the camera, it's more or less pronounced. For example, digital video cameras that have lower resolution or lower image quality will actually show less of this effect, while cameras that have very clean, very sharp and very high true resolution will display more of it.
It has got to do with the way the shutter works - it's basically ON/OFF/ON/OFF sequence, so when you pan fast, you'll notice it simply because the rapid movement in combination with frame rate and shutter speed will create those stutters. The speed at which the sensor is capturing frames is not sufficient to create smooth movement transition. In film cameras the shutter works differently, instead of the ON/OFF it's more like a curve, going smoothly from ON to OFF position. That's why you can't see this in film shots.
And just in case you're thinking FS700 is somehow bad in this regard - it's not. Even top production digital cameras display this effect. Pay attention and I'm sure you'll spot it in a lot of movie and TV production. I know I do.
Ways to alleviate this issue: avoid very fast pans, use shallow depth of field to blur the background and especially avoid doing fast camera movement when shooting dark vertical motifs against a bright backdrop (or the other way around). Also, setting camera sharpness settings helps a bit, and lowering in camera contrast.
Thanks Drazen but i know exactly what motion judder is and by no mean i was saying anything about the F700, i have an F3 not the FS.
The problem on the F3+DP6 on progressive shooting (not interlaced) is that when you pan, every second or so a frame is repeated, it's really faint but if you're panning you will feel it.
On interlaced it's not there.
It's like the 25P signal is interpreted as 24 or something.
Even SmallHD acknowledged the problem but not solved it yet.
I will have to try it on HDMI input and also on another camera to see if it's a signal problem with the F3.
Oh, sorry mate, since it was posted in FS700 forum I assumed you had it. I guess it's a problem with DP6 then, but I honestly have to say I haven't noticed it, and I also shoot in 25p. Will take a closer look next time and report back.
